Results 1 to 9 of 9
Thread: Table
    Jul 2009
    Harbour Grace Newfoundland
    Default Table
    When i first saw the cnc in action 10 years ago .I knew the machine was a game changer .The table has 15 or 20 coats lost count is polished used 2k urethane the base is metal
    Will deliver wed
    That don't look like no concrete to me!
    Well Done Kevin-Beautiful!!
    NICE Kevin!!!
    Feb 2015
    NC, USA
    Very nice!
    Feb 2015
    Alberta
    Gorgeous! It looks like a anchor on something that I can't make out from the photos. What is the background image to the anchor?
    Jul 2014
    Bell, Florida
    Awesome!!!
    Tim Lucas Custom Woodworks
    www.TLCW.us
    Jul 2011
    Timmins, Ontario, Canada
    Lovely. I love Mahogany, as you probably know.
    Im interested in the construction - at first I thought it was from 8/4. but looking closer it looks like the top is thinner, banded with another molding and then skirted?
    As a fellow furniture builder I am always interested in the details of construction... please
    Also, how thick is the accent stripe set into the top? I havent done too much of this stuff that wasnt done in true veneers (laid up, taped and pressed to a substrate, VS setting in strips in a solid wood top).
    Where is this headed, Kevin? Another boat?
    Jasper, TX
    Very beautiful. Like Andrew I'm interested in more details.
    Jul 2009
    Thanks for the complements yes its an anchor with teak and purple heart the edge was Spanish cedar no stain
    Andrew to answer I used 4/4 for the put the inlay than took another quarter off using the bot in I ended up about 1/2 thick .I laminated to 2 sheets of mdf .the wood was pl on the mdf respecting the wood movement .The skirt hide the mdf I v groved the edge to give a line if the wood move won't show an crack or a line .I didn't use 8/4 because wood movement would might push up the caving .
    This table was designed all material that can go on a boat .I'm not comfortable using veneer in these waters i learned a lot on the last yacht its brutal the dampness .It has to bee solid .the carving and edging ended up being a 1/4 thick
    The table is at the ship yard board room i deliverer today the base on the 12 inside the top is rock solid was surprised no tipping will post final picture later
  1. Would like vac table recommendations for 96-60"table
    By Plyoboxwarehouse in forum Variations & Modifications of ShopBots
    Last Post: 01-30-2015, 03:13 PM
  2. Replies: 5
    Last Post: 11-28-2005, 01:08 AM
