Results 1 to 7 of 7
Thread: Chairs
    , Coventry CT
    Default Chairs
    We are making androndic chairs is there anyway that we can cut out desins and such what bits ECT
    Jun 2005
    American Heritage Woodworks, Delta CO
    I believe Trevor is looking for designs for Adirondack chairs and would like suggestions on the bits to use.
    Mar 2005
    , Alexis Illinois
    I did a google search for "free adirondack chair plans" and came up with several, even a love seat rocker style. If need help finding them email me and I will send you email links.
    Gerald Wilson
    , Coventry CT
    I have the designs and everything but i just wanted to know if i made the parts on autocad can i import them and as what file and what bit will cut all the way through.
    Sep 2004
    The Traditional Rocking Horse Co.,
    Trevor
    What software do you have to convert .dxf files to .sbp files.
    There is a conversion possibility within the Shopbot software , but a little limited.
    Presuming you are making the chairs from a hardwood, you will probably not be able to cut right through with a single cut.
    I regularly go no more than 5mm (1/5") deepcutting in hardwood.
    Bits often reflect the preferences of the user. For very clean cuts straight two flutes are good. Spiral upcuts may be a better choice, depending on how you will finish the chair.
    Whatever bit you choose, either the cutting length must be equal or greater than the thickness of the timber, or the shank must be the same size as the cutting diameter.
    ..............Mike
    , Coventry CT
    When i try to convert it. i get a pop up that says [3604] invalid ArtCam File (2)
    Also says
    Failed to create Model
    Sep 2004
    Trevor
    send me a .dxf file, I will try to help
    .........Mike
  1. more chairs...
    By Ajcoholic in forum Folder 2016
    Last Post: 09-25-2016, 09:02 PM
  2. chairs
    By fabrun in forum Folder 2013
    Last Post: 02-11-2013, 03:45 PM
  3. some 3d chairs
    By fabrun in forum Folder 2010
    Last Post: 07-27-2010, 06:59 AM
  4. Chairs?
    By blake_koehn in forum ShopBotter Message Board
    Last Post: 01-06-2009, 07:26 PM
  5. Chairs
    By phd1658 in forum ShopBot Businesses
    Last Post: 12-04-2008, 09:32 PM
