Results 1 to 5 of 5
Thread: Router won't turn on, then error "not enough axes designated for a command in use..."
    Jul 2004
    Campton, KY
    Default Router won't turn on, then error "not enough axes designated for a command in use..."
    Desktop has been working fine. I created a part file with Vcarve Pro 7.5. When I ran it, the router did not turn on (switch is on) and it began moving X&Y. I hit stop and I got an error message "Not enough axes designated for a Command in use. Use [VD] to enable additional axes.". I ran a known good part file and the router started up before moving. I hit stop and no error message.
    'SHOPBOT ROUTER FILE IN INCHES
    'GENERATED BY PARTWorks
    'Minimum extent in X = -0.125 Minimum extent in Y = -0.125 Minimum extent in Z = -0.750
    'Maximum extent in X = 24.125 Maximum extent in Y = 18.125 Maximum extent in Z = 0.000
    'Length of material in X = 24.250
    'Length of material in Y = 18.250
    'Depth of material in Z = 0.750
    'Home Position Information = Bottom Left Corner, Material Surface
    'Home X = 0.000000 Home Y = 0.000000 Home Z = 0.500000
    'Rapid clearance gap or Safe Z = 0.125
    'UNITS:Inches
    IF %(25)=1 THEN GOTO UNIT_ERROR 'check to see software is set to standard
    SA 'Set program to absolute coordinate mode
    CN, 90
    'New Path
    'Toolpath Name = oring test
    'Tool Name = Ball Nose 1/16" Dia.
    &PWSafeZ = 0.125
    &PWZorigin = Material Surface
    &PWMaterial = 0.750
    '&ToolName = "Ball Nose 1/16" Dia."
    &Tool =26 'Tool number to change to
    C9 'Change tool
    TR,10000 'Set spindle RPM
    C6 'Spindle on
    PAUSE 2
    MS,0.2,0.2
    JZ,0.500000
    J3,14.383664,1.860111,0.125000
    M3,14.383664,1.860111,-0.031300
    CG, ,14.539914,1.703861,0.156250,0.000000,T,-1
    CG, ,14.696164,1.860111,0.000000,0.156250,T,-1
    CG, ,14.539914,2.016361,-0.156250,0.000000,T,-1
    CG, ,14.383664,1.860111,0.000000,-0.156250,T,-1
    JZ,0.500000
    J3,0.000000,0.000000,0.500000
    'Turning router OFF
    C7
    END
    UNIT_ERROR:
    CN, 91 'Run file explaining unit error
    END
    Garland Tx
    Tool 26 is a tool number reserved for a second Z axis… Have you got one?
    Jul 2004
    Campton, KY
    No, just one Z. I did not know that. Interesting. I will renumber the tool and try again. Thanks!
    There was a version of SB3 3.8.XX that started giving me this error also and it would randomly happen for no good reason. If you are using a older version of 3.8.XX, update to 3.8.40. Be sure to update the firmware after updating the software.
    Garland Tx
    FYI… Z axis tool numbers can be 1-19. A axis (second Z) can be 20-29.
  1. "Missing Comm Return" error
    By MDCochrane in forum ShopBotter Message Board
    Last Post: 10-13-2015, 08:35 AM
  2. Another dreaded "Failed to import data" error message
    By jim shula in forum ShopBotter Message Board
    Last Post: 08-11-2015, 09:40 AM
  3. "Label finding error" hmmmm?
    By david_beede in forum Troubleshooting
    Last Post: 05-09-2013, 06:42 AM
  4. Router doesn't turn on when "Start" is selected
    By kartracer63 in forum ShopBotter Message Board
    Last Post: 01-12-2011, 11:26 PM
  5. Getting "Missing Comm" or "Communitation Error"
    By dengler in forum ShopBotter Message Board
    Last Post: 07-02-2010, 04:22 PM
