Quote Originally Posted by Mike Windsor View Post
It might be 4 mm that I cut
I'd definitely be interested in the drag knife if it could cut it
It does alright, but not the ideal material for sure. The stuff I have is 4mm. I cut this diamond shape out (8" pt. to pt.), so the edges are at 45 degrees to the grain. The edges are pretty straight. I was just on double sided tape on a metal plate, so I wasn't able to dig into the MDF for any help. That should help. Also, the drag knife gadget tears a little on exit which I did not attempt the clean up in the code.
