Rick, here are the specs (copied from site)
Features:
#19 heavy duty Exacto(TM) blade.
Two double sealed bearing rated for 310 static / 750 dynamic pounds radial load
Hardened steel 3/8" shank
Drag offset is 3.0mm
Max material thickness: 3.0mm
Min radius: 3.0mm
Length from collet: 72mm (2.84")
Kit comes with a pack of 5 blades and hex key
Vectric VCarve Pro and Aspire have a "Drag Knife" gadget that can do some cool things for calculating toolpaths. You can use it without that software, but I need to do some research on what the specifics are. Basically, with the spindle off, you can run a profile toolpath and observe where it starts and adjust the blade starting angle manually. When going for more than one profile, you have to be aware of the blade angle, which is what the vectric software does (very cool)
