Have these been posted before?
I had thought about that a long time ago, just never did anything about it. Good idea.
Words of Wisdom:
Those of you with and indexer, how about a guesstimate about how long to cut one of these. They are fantastic. Talk about a unique craft show project, wow! This may be the product / idea to get my indexer on the drawing borad. Thanks for posting. Russ
AKA: Da Train Guy
Hey Russ...I think I remember seeing a setup that held a round blank directly below the bit and traveled back and forth with the gantry. Seems like the blank just rolled on the table and you cut it as a flat file who's length was the same as the circumference of the blank/rolling pin.
Anyone else remember that, or did i just dream it?
Should not be any difference in cut time than carving the same pattern from a flat sheet of the same surface area. My best guess for my own machine would be 10-20 minutes with a vcarve and flat bottom bit, plus roughing the precise dowel diameter. But there are a lot of variables.
I have seen such rolling pins but was always wondering why they usually only imprint the surface pattern and not the cutout shape of the cookie. I guess that would be easy enough to do as well? And while not looking as nice, making from HDPE might be easier to clean.
Yes, Bill, that sure sounds familiar!
Are these laser cut?
Very nice.
I believe most of these are made using a laser cutter with an indexer.
Bill, I think the indexer you are talking about is something someone came up with on the Shark Forum. Also I think someone on the CarveWright Forum has something similar...joe
