Hello!
I just purchased a PRT Alpha 60x120 with SEV HSD AT/MT 1073-140 Spindle and Yaskawa V74X VFD.
Does anybody on this forum have this combination? If so, could you open your VFD and snap a few pictures?
A brown wire (a black and white small control wire in a brown jacket) that goes between the control box and the VFD was tugged a bit too hard when we were taking the control box and VFD off the wall at the place I bought it. It pulled the brown wire out the bottom of the VFD. So, I did not get a chance to see where it was supposed to be terminated.
I have it home now, and under power. But, I can't use the RPM control box in partworks to change the VFD speed. This leads me to believe the brown wire was the link between the control box and VFD to adjust speed. The VFD can power on, and you can manually adjust speed using the buttons on the face of the VFD itself.
I opened the silver control box, the brown wire has a white, and a black small wire connected to the VFD(1) DCM and FWD terminals on the control board as they should be. The wire goes to the VFD, through the rubber grommet. There are two loose terminals inside the VFD where the screws are not all the way tightened. I am thinking they might be the ones where the wires pulled out and should be connected? There is also one black wire coming from the orange cable from the spindle that is not attached to anything. Not sure if that was already like that, or was attached to one of my two disconnected wires from the control box.
The instruction manual (original that came with shopbot in 2004) has instructions for wiring a "Colombo Spindle" which I do not have. The previous owner has a page printed out from the manual, then some hand writing scratching out the part that shows the terminals to connect to inside the VFD. This is probably since it does not really match the inside of the Yaskawa vfd that I have. Their notes say something about "not for our driver" or something. So... I am lost where to connect to and don't want to short anything out guessing on making connections.
I found this guide, but it only states that the "brown wire comes from the VFD" and then tells you where to connect into the control box. I have the reverse, its connected to control box, but not to the VFD now...
http://www.shopbottools.com/ShopBotD...%2009%2024.pdf
Questions:
1. Can this shopbot control spindle speed via partworks? both manually, and if I program tools in partworks to run at different speeds?
2. where do I connect the black and white wires (in brown jacket) inside the VFD?
Please see these pictures for clarification.
Installed in wood boat building shop in Olympia, WA:
Reinstalled in my garage in Colorado:
Spindle
VFD
Inside control box. Brown wire is terminated per correctly per the original shopbot manual.
