Results 1 to 4 of 4
Thread: ATC problems
    Jan 2016
    Orlando, FL
    Default ATC problems
    In the midst of cutting a part the rear dust skirt gate caught a hold-down clamp and I broke the shaft on one of the pneumatic pistons.
    So, I'll have to order another one.
    In the mean time, how do I manually change my .sbp code to not look for the numbered tool?
    Or what's the easiest way?
    I've tried to go back into vcp, edit the toolpath to show tool as [0], but now when trying to start the part file, the ShopBot still wants to return to the ATC at the back of the table.
    I know it's something simple that I'm missing here...
    PRS Alpha 96" x 60"
    cnc routing, portland or
    just change the post processor to one without the atc you would have to change the tool to 0 too
    Jan 2016
    Orlando, FL
    I was able to fix the broken pneumatic piston, so I didn't have to bypass the ATC
    Thanks, though!
    PRS Alpha 96" x 60"
    thats the best solution if possible. myself I would keep screwing up because the rythem has not changed in a long time.
  1. Anyone else having problems with pic?
    By scottp55 in forum About this Forum
    Last Post: 02-25-2015, 01:05 PM
  2. C3 problems
    By miked in forum Troubleshooting
    Last Post: 07-12-2012, 08:57 PM
  3. Problems with SB 3.6.36
    By phil_o in forum ShopBot Control Software v3
    Last Post: 10-11-2011, 11:24 PM
  4. Z-Zero Problems
    By wardsa in forum Archives2007
    Last Post: 06-30-2007, 08:20 AM
  5. Z-zero problems??
    By woodesign2@juno.com in forum Archives2006
    Last Post: 03-27-2006, 06:43 AM
