Thread: Upgrading drivers & motors a PRS standard ?
    Apr 2008
    , TROIS-RIVIERES QUEBEC
    Default Upgrading drivers & motors a PRS standard ?
    OK, I own a PRS standard 4 x 8 (2007), I think first year they came out. This tool is running great, I am cutting cabinet parts with the link at 7 ips (2 passes) but I am right on the edge for speed and the compression bit needs to be sharp. I would surely use more torque (changing drivers and motors) to maybe double the torque which is at 75 lbs right now. Any of you did it without going to Alpha set up (I don't need closed loop system, and I like the way a standard works). I need a direct replacement that will keep the modification simple and quick. Any suggestion is welcome.
    Mar 2009
    n/a, Vancouver BC
    Why are you not wanting to go to alpha? Increased torque and resolution, operating should be the same for you with better results.
  1. PRT Standard Stepper Motors and Controller
    By human61987 in forum For Sale/Wanted - ShopBot-related items only
    Last Post: 12-12-2016, 09:52 PM
  2. Replies: 7
    Last Post: 01-04-2010, 03:40 AM
  3. USB Drivers
    By jamess in forum Troubleshooting
    Last Post: 08-16-2009, 03:25 PM
  4. Upgrading a PRS standard 48x96" to Alpha
    By kodiak in forum Archives2008
    Last Post: 10-02-2008, 08:04 AM
  5. Alpha 7.2 motors or PK299-F4.5A motors?
    By richards in forum Developers
    Last Post: 11-29-2007, 01:18 PM
