Results 1 to 10 of 14
Thread: Stepover
    Feb 2015
    NC, USA
    Default Stepover
    When making a profile cut with multiple passes, does the software ignore the stepover value?
    Delray Beach, FL
    yep.
    Since you're not stepping over in your toolpath, which is a setting more relative to area clears and/or "3-d" work, makes sense, right?
    Been following your questions Will. We all started with no idea either. Some of us long before the software had nearly as many good tutorials like they do now.
    You should take advantage of them. Will definitely help you big time.
    Test stuff in cheap materials is a big plus too.
    Feb 2015
    NC, USA
    Thanks for the help. I thought that was the answer but wanted to check. I have look for it but everything talks about 3D or pocket.
    I find myself going back to the tutorials a lot.
    I am going to the Aspire camp next month, I hope to learn some new things there.
    As always thanks again!
    Will
    Feb 2010
    SOUTH CENTRAL COLORADO
    You never stop learning. Thanks for asking that question. Because after so many years i did not know the answer either.
    Norman, Ok
    Here an old file from a job completed a few years ago using step over as a creative tool. Using a 1/4" ball nose bit with a 1/4" step over. Imagine what can be done with other bits with more or less stepping.
    May 2015
    SF bay area, CA
    Like Joe I design some products to showcase the process of cutting them on the CNC
    www.byronconndesign.com/store
    Feb 2015
    NC, USA
    very nice guy's, thanks for sharing.
    I was cutting 1/4 aluminum and was getting a small step and just wondered it that could have been the issue.
    I don't know, maybe I'm getting a small bit of bit deflection.
    You all are awesome, thanks for all the help!
    Norman, Ok
    Who knows without seeing. Can't imagine asking for help without a photo.
    Feb 2015
    NC, USA
    Joe,
    That really wasn't a question, I was just explaining why I asked the question.
    However I will post a pic tomorrow when I get back to the shop, maybe you all have see it before. I know the gantry is not loose and I have new motors on the machine. It doesn't happen on all passes.
    Quote Originally Posted by joe View Post
    Very creative! I like that. Never thought about doing that before.
  1. Bit Stepover percentage
    By jTr in forum ShopBotter Message Board
    Last Post: 04-24-2013, 12:37 PM
  2. V-Bit Stepover and Stepdown Recommendations
    By jdervin in forum Techniques for Cutting, Drilling, Machining
    Last Post: 09-20-2012, 11:48 AM
  3. Creative Stepover
    By joe in forum Sign Making
    Last Post: 04-25-2010, 10:27 AM
  4. V-bit High-Stepover Fun
    By zorlack in forum Folder 2009
    Last Post: 03-29-2009, 05:45 PM
  5. V bit stepover for reliefs
    By bleeth in forum Archive2008
    Last Post: 10-06-2008, 07:00 AM
