Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Stepover
  1. #11
    Norman, Ok
    That techniques came about my desire to bring more interest to the lettering. This was a project with back lighting. The letters ended up being about 23" in height.
  2. #12
    Apr 2007
    Bancroft Ont Canada
    I am trying to make a cut with multiple passes WITHOUT a step over. After reading the prior question, the program should ignore the stepover however it does not. It is stepping over to the outside when I am trying to cut the inside. What am I doing wrong?
  3. #13
    Feb 2008
    Miller Marine Products, Ridgefield Washington
    Quote Originally Posted by dldalley View Post
    Check the drawing and make sure it is a closed vector you can right click on the vector and if you get the choice to close it by moving end points or with a straight line it is open you can also look at the nodes in node edit mode. I suspect your vector is open and that is why this is happening.
    Mike
    WWW.MillerMarineProducts.com
    Proto Trak DPM CNC Bed Mill
    Brand X Industrial router
    Sharp SVL-2416SE-M VMC
  4. #14
    Mar 2017
    Default Joe
    Joe is always creative.
  1. Bit Stepover percentage
    By jTr in forum ShopBotter Message Board
    Last Post: 04-24-2013, 01:37 PM
  2. V-Bit Stepover and Stepdown Recommendations
    By jdervin in forum Techniques for Cutting, Drilling, Machining
    Last Post: 09-20-2012, 12:48 PM
  3. Creative Stepover
    By joe in forum Sign Making
    Last Post: 04-25-2010, 11:27 AM
  4. V-bit High-Stepover Fun
    By zorlack in forum Folder 2009
    Last Post: 03-29-2009, 06:45 PM
  5. V bit stepover for reliefs
    By bleeth in forum Archive2008
    Last Post: 10-06-2008, 08:00 AM
