Results 1 to 10 of 18
Thread: F1 In School and Indexer
    Jan 2015
    Little Rock, AR
    Default F1 In School and Indexer
    I'm a teacher (Project Lead the Way - Intro to Engineering) using F1 in Schools - CO2 cars - projects in my course.
    I have the Shobot Desktop use use for TONS of different projects but I haven't used the Indexer other than a few projects needing symmetric round parts - so I know the basics for using our 3" indexer.
    I'm HOPING we can use the Destop/indexer to meet the CNC requirement of the competition so I don't have to get a different machine - I really love my SP
    We are required to use a pre-cut (official) block which was Balsa previously, but is a type of plastic starting next year. The dimensions are here:
    As you can see, this is a square block!
    About 2.5" x 3" x 8" long
    The model I'm trying to chunch out looks like this:
    Is this even possible?
    Thanks for any tips and suggestions you might have for me!
    - Les
    Jan 2015
    Little Rock, AR
    ... Humm, its been a few days, not looking too good for us to use the indexer.
    I'm still researching though - any tips are appreciated!
    - Savoy/Les
    Jun 2001
    Austin, TX
    You could do most of it on the indexer. What software do you have? You might be better off doing a 2or 4 sided machining strategy. The rear airfoil would probably be a problem.
    Feb 2013
    River Fall WI
    I have been plan running some CO2 cars on ours and I plan on using 2/4 sided machining.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Aspire 8.5, Creo 3.0
    Jan 2015
    Little Rock, AR
    Quote Originally Posted by waynelocke View Post
    That is what I'm hoping (having the indexer do most of the work) - I'm using Aspire 8.
    Apr 2007
    Marquette, MI
    Savoy...
    Do you have a 3D model for the car body? That would be the first step. That design can be cut, but with some difficulty. It appears that it may be best cut affixed to the rotary via an arbor. Which creates a new set of problems for the front of the car as it will be below the axial center and Aspire will not like that.
    Your project can be cut, but it not going to be an easy one, especially if its a first 3D on rotary project.
    Gary Campbell
    GCnC Control
    GCnC411(at)gmail(dot)com
    Servo Controller Upgrades
    Albert Einstein
    Jan 2015
    Little Rock, AR
    Quote Originally Posted by Gary Campbell View Post
    Savoy...
    Do you have a 3D model for the car body? That would be the first step. That design can be cut, but with some difficulty. ...
    Yep... have the body modeled in AutoDesk Inventor which I can bring into Aspire as a model. I'll see if I can fine a way to upload the files here so you can see it the actual model. Here is a screen shot of it though.
    Looks like I'll encourage them to go with the 2-sided cut. We have to do some of this on the CNC machine to meet the competition requirements for F1 in Schools.
    Apr 2007
    Marquette, MI
    Savoy...
    Do you have any CAM abilities from Autodesk? The reason that I ask, is that you could use Aspire or VCPro to Cut the model, but it would involve some trickery to keep the portions you need to cut above the zero plane, which would be the axial center in most cases. You might also look at Cut3D as it supports 4 sided machining, albeit without the rotation of the indexer, which you could do easily from the keyboard.
    Gary Campbell
    GCnC Control
    Albert Einstein
    Jan 2015
    Little Rock, AR
    Thanks for the tips Gary.
    I'm going to have to use 2-sided through Aspire. I have what comes with the shopbot and a full copy of Aspire 8 so I'm going to try and pull it off with that.
    An example of the model we are going to try and tool is attached here. I think 2-side cuts will work.. I'll just need to be careful when pulling it in (I'll have to align it center and to the back of the block where my CO2 hole is pre-cut).
    I'm working through the videos on 2-sided cuts now - and I'll try a few cuts with pine blocks over the weekend and see how it goes
    Attached Files Attached Files
    Jan 2015
    Little Rock, AR
    Thanks for all the tips... I've learned a lot about the indexer and have thought of a lot of cool future projects to use with it, but I'm going to go with two-sided milling for this project. I've already made the jig that will hold the pieces (it's an official blank for this competition).
    Thanks and for the encouragement and support! - Savoy/Les
  1. Setting up a school
    Last Post: 10-01-2014, 06:36 AM
  2. School Sign
    By gsmith in forum Folder 2011
    Last Post: 11-21-2011, 06:59 PM
  3. 8' Ant for Elementary school
    By mccoy178 in forum Folder 2008
    Last Post: 07-29-2008, 03:57 PM
  4. Albany High School School Son
    By ryan_slaback in forum Folder 2007
    Last Post: 01-16-2007, 04:31 PM
  5. Trying to use ShopBot in School
    By Rollie Peter (Unregistered Guest) in forum ArchivesSchools
    Last Post: 04-12-2004, 08:21 PM
