Results 1 to 7 of 7
Thread: Vacuum Grid/Plenum Question
    Mar 2015
    Somerset, KY
    Default Vacuum Grid/Plenum Question
    Hello, we bought this used 144"x60" 2012 Alpha and the spoilboard was glued using some sort of silicone and was coming off. IMG_0889.JPGIMG_0888.JPGIMG_0887.JPG
    So, if I resurface the grid a tad would I have to re-apply shellac? Also should I put more glue than what they had, they only put a small amount around the edges. What are your suggestions for getting this silicone off?
    2009 BT48 RBK With 10' Powerstick
    2HP HSD Spindle
    2012 PRS ALPHA 144"X60"
    Republic Blower Hold Down
    4HP HSD Spindle
    VCP 8.014
    Jan 2016
    Phoenix Arizona
    Running a table surfacing program from the SB software would remove the remaining silicone caulking but because the plenum is MDF, you would want to seal it again if you resurface it.
    I just did our table surface and used silicone caulking to hold down the spoil board to the plenum. The caulk was placed around all the vac zones to help with zone isolation and also on roughly 10% of the "nubs" inside each zone.
    Working for us.
    Feb 2013
    River Fall WI
    We only seal the grid and glue the whole top down (all zones and all nubs).
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Aspire 8.5, Creo 3.0
    Mar 2015
    Somerset, KY
    Quote Originally Posted by Kyle Stapleton View Post
    I have seen this done and was hoping I would get an answer confirming that it works well.
    2HP HSD Spindle
    4HP HSD Spindle
    VCP 8.014
    May 2015
    SF bay area, CA
    Works great, the better you can seal the edges of the grid to your bleeder the better your vacuum will be. An ultralight MDF works best as a bleeder and don't forget to surface the outer skin on both sides of your bleeder and seal the edges.
    If you feel like upgrading using a rigid plastic for the vacuum grid is the way to go.
    Mar 2015
    Somerset, KY
    Quote Originally Posted by ByronConnDesign View Post
    The previous owner did not surface the outer skin on both sides... I was wondering why they didn't.
    2HP HSD Spindle
    4HP HSD Spindle
    VCP 8.014
    Sep 2015
    Buford, GA
    I used wood glue to both seal the plenum AND glue the bleeder down. It's MUCH less expensive than Shellac. I also didn't know what would happen if I tried to glue a surface finished with shellac. But, wood glue is CHEAP.
  1. Vacuum Plenum
    By Bill Keehn in forum Variations & Modifications of ShopBots
    Last Post: 10-09-2014, 01:44 PM
  2. Vacuum plenum sealer question???
    By gundog in forum ShopBotter Message Board
    Last Post: 05-08-2011, 05:47 PM
  3. vacuum plenum
    By cabnet636 in forum ShopBotter Message Board
    Last Post: 09-24-2010, 08:17 AM
  4. Extira Vacuum Plenum
    By anthonyjules in forum Assembly & Maintenance
    Last Post: 04-06-2010, 09:29 AM
  5. Vacuum plenum
    By dingwall in forum Archives2007
    Last Post: 04-09-2007, 11:24 AM
