Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Good Saw For Cutting Tabs
    Aug 2012
    Davenport Iowa
    Default Good Saw For Cutting Tabs
    I am looking for a recommendation for a good saw for cutting project tabs.
    Sometimes it is a close cut and need a flexible blade.
    Thanks for your help
    Life is like a project you continue to work on until it's finished.
    Never start a project you don't intend to finish!
    Delray Beach, FL
    Here's a few links that should get you what you need.
    First is American version of Japanese pull saw. I picked up a similar one years ago at HD (Grey handle) and it flexes somewhat but stays stiff enough when using it on deeper cuts.
    Second is one sided handle for hack saw blade-Have kept one in my toolbox forever.
    Third and fourth is a whole bunch of Japanese saws for you to go through-I have a dozuki and a shinwa and love them and also one flush cutting that is very small and very flexible. I've come to really love cutting on the pull-much more accurate and user friendly than push saws.
    Main thing is to make sure it is "flush cutting". Less sanding!
    http://www.homedepot.com/p/DEWALT-Fl...0541/203040590
    http://www.homedepot.com/p/Milwaukee...0012/202523986
    http://www.amazon.com/s/?ie=UTF8&key...p6uaui8r_b_p10
    http://www.japanwoodworker.com/categ...hand-saws.aspx
    Jan 2014
    L.I. N.Y.
    May 2015
    SF bay area, CA
    Here are my absolute favorite saws. I use the Kugihiki flush cut and Dozuki dovetail saw all the time. Super thin kerf and stay sharp a long time. http://www.leevalley.com/us/wood/pag...86&cat=1,42884
    Oct 2000
    Willis Wharf, VA
    This is what we supplied to customers to cut tabs when we did MakeLocal with Opendesk at the NY Maker Faire. I save old hacksaw blades that are dull in the middle but sharp on the ends, and the guy that sharpens my saw blades also make bandsaw blades, and always has a bunch of offcuts of bandsaw material that he's happy to give away. Grind off the sharp corners and add a couple of pieces of heatshrink or tape around the handle end to protect your hand and it's good to go.
    Feb 2011
    I use a scroll saw, of course probably would not be worth it if cutting tabs is all you do with it
    Doug
    Feb 2010
    SOUTH CENTRAL COLORADO
    chances are i am using the wrong saw. But what i have learned is that when i try cutting close to my piece i chip off a lot on the back. So now i cut away from the carving and use an oscillating sander to sand down the tab. But i see a lot of potential here to be my next saw.
    Jul 2005
    Brookline, New Hampshire
    You might try this instead : Amana Tool MR0102 Flush . I use the bit in a battery powered laminate trimmer.
    It will cut the tabs flush and takes very little time. The bit that creates the tabs needs to be 1/4" or larger.
    Jun 2004
    Springfield Mo
    Default Dremel tool
    Dremel tool with a cutoff wheel works well.
    Wear safety glasses.
    Feb 2010
    NEVER even knew that Amana Tool MR0102 existed.
  1. Squealing noise when cutting tabs?
    By hipstomp in forum ShopBotter Message Board
    Last Post: 06-30-2015, 09:49 AM
  2. Replies: 29
    Last Post: 06-16-2015, 08:43 PM
  3. A Good Place To Buy Good Drawer Slides?
    By shilala in forum ShopBotter Message Board
    Last Post: 02-10-2013, 07:06 AM
  4. Tabs, Tabs and more Tabs
    By twelchPTM in forum Designing and Creating the sbp cutting file
    Last Post: 08-21-2012, 08:35 PM
  5. Tabs
    By chuckster in forum Archives2008
    Last Post: 05-09-2008, 04:17 PM
