because i think some of these saws would be too wide to go into a crevice on some carvings that are curved i'd use a rotozip tool and then sand your nub down.
Words of Wisdom:
Lots of great choices!
Thanks to all!!
Life is like a project you continue to work on until it's finished.
Never start a project you don't intend to finish!
I use a jig saw to cut tabs.
Don
www.dlwoodworks.com
I generally use a jig saw but I put a metals cutting blade in to eliminate tear out.
Off the table, battery powered jig saw and either a flush trim bit or the edge sander. On the table, a veneer saw or oscillating multi-tool followed by the same flush trim bit or edge sander.
We use the Veritas Flush cut trim saw that the guy is holding in his hand in the pic.
Had 3 of them from building the house 20 yrs ago, and started using when we got the Desktops.
I have both of them, but prefer the single edge for tabs.
http://www.leevalley.com/us/Wood/pag...28&cat=1,42884
Tom Bachman,
Lakin, Kansas
2001 PRT4896
Learned about this bit last time this question came up. Bought one, burned bearing in very short order (very delicate bearing -due to small size, seems no option for a more robust bearing)NEVER even knew that Amana Tool MR0102 existed.
Went back to rough cut with bosch cordless mini sawzall. Clean up with 1/4" whiteside down spiral double bearing flush trim bit.
Jeff
I use a cheap Harbor Freight multi tool and a skinny multi tool blade. Works for me. Russ
AKA: Da Train Guy
I use an extremely sharp and small wire cutter then use a variety of sanders (disk, spindle) to clean it up. I find using a saw often leads to tear out.
