Hi guys, first post here. I've spent the past couple days reading through this forum on vacuum table set-ups and I think I have an idea of what I want to do now, but I'd like to run it by you guys and get some input, and also ask a couple questions. This is a great forum for DIY vacuum table knowledge, I haven't found more in depth info anywhere else on the web, so let me say thanks for that!
The work:
The table is going to be a 48"x48" working area setup. I will be cutting PTFE in 48"x48" sheets and cutting them into various basic shapes. Mostly circles and rectangles of varying sizes. Maximum thickness of these sheets will be 3/16" but the majority will be 1/4". Many of these pieces will be small, as in 9 sq inches or even a little less sometimes. Generally they will be rectangles ranging from 8" x 3/4" up to 2" x 20" for the smaller pieces. The larger pieces I'm less concerned with because they will generally be 100 sq inches or more and rectangular or circular.
I will also be doing some engraving on this table, but that will be a solid sheet of thin stainless or aluminum which I will then shear into size after the fact, so probably not much of a concern as far as table requirements go?
The table:
I'm planning on building a universal set-up with a 3/4" ultralight spoiler. The plenum, I'm still deciding on the pattern. I'm thinking .5" to .75" channels with 4 zones. I plan on using two lighthouse motors (or similar) and building a housing for them and running 2" PVC to the zones with one motor running two zones each. I will run individual shut offs for each zone for more fine control over the vacuum.
The questions:
What size channels in the plenum would be better for what I'm looking to do?
Can I just use cheap 2" PVC ball valve shut offs? I'm curious as to why every one opts for the much more expensive guillotine style valves.
I see a lot of people use MDF for the plenum and coat with watered down wood glue a few times to prevent leaks. What about using fiberglass resin?
What motors should I run for this job? I don't have much of a budget, maybe $500 for everything give or take. I do have access to 240v near my table. There's a lot of options and I'm not sure what will suit my needs the best. I'm guessing more CFM the better with a spoiler board set-up.
Has anyone ever used transfer tape to mask off areas of the table that aren't being used? If I have to cut a piece of scrap or something on one zone and need to mask off the area around that zone, would that be a viable option, is what I'm asking.
