Results 1 to 10 of 11
Thread: Key Hole slots
    Sep 2008
    2328 Morris Creek Road Stanton, KY.
    Default Key Hole slots
    How do you tool path for a Keyhole bit. How do you get it to plumnge move over and then back to the same hole to extract the bit??
    www.tgdesigns.net
    eking1953@yahoo.com
    ST. FRANCIS OF ASSISI
    Aug 2013
    Clayton, NC
    In Aspire, I just create a small circle where I want the starting hole to be, then select it and choose the "Keyhole Toolpath" from Gadgets. Tell the the direction and length and it does the rest.
    Daniel E.
    Porter Cable Router
    Vacuum Table w/ 2 Fein vacs
    Aspire 9.0
    Garland Tx
    The old fashioned way, before “gadgets”, was to draw a “U” shape with only a few thousandths between the legs, tell your software to cut “on the line” at a specified depth. The router will go to the start node, plunge to the specified depth, follow the “U” over and back, and retract to your material clearance depth. You, naturally, must use a keyhole bit…
    cnc routing, portland or
    or even a pocket as long as you make sure of the start point.
    Using the line tool in VCP/Aspire, click to set the start point, click the end point (or fill in the length/angle value and add), and then click/snap to the start point again to finish the line. Toolpath on the line at the proper depth with use vector start points enabled. It will plunge at the beginning, travel the distance, return to the start point and raise up. Save that toolpath as a template to quickly load and use the next time you need to toolpath keyholes.
    Cleveland TN
    I do mine the old fashioned way, gives it a bit of an angle to bite into the screw as you hang the piece. Of course this assumes that you are using a keyhole bit:
    J3,1.0000,43.6250,0.4000
    J3,1.0000,43.6250,0.1000
    M3,1.0000,43.6250,-0.350
    M3,1.0000,42.8750,-0.4000
    2005 PRT Alpha 48x96
    2013 Colombo 3hp spindle
    Indexer (converted lathe)
    Aspire 9.0
    Feb 2008
    Miller Marine Products, Ridgefield Washington
    I do it the old fashioned way by creating a poly line make a start point then the next point is the end of the slot then you make the last point the same as the start point. The tool will go down and back without lifting until it gets to the last point which was the same as the start point. I was doing this before they had the gadget and since it works I never changed the method.
    Mike
    WWW.MillerMarineProducts.com
    Proto Trak DPM CNC Bed Mill
    Brand X Industrial router
    Sharp SVL-2416SE-M VMC
    Mar 2011
    Marietta, Ga.
    I would be careful of my feeds and speeds. I have a standard Buddy and I managed to make it lose some ('lots) of steps the first time I tried this. I used the Vectric gadget but forgot about pushing the bit too hard...joe
    Feb 2015
    Alberta
    Scott,
    I've never saved a toolpath as a template. Is there a tutorial on it?
    BTW, thanks for posting your routine for work offsets. I always learn more from looking at some code then reading a manual.
    I haven't figured the button thing yet but that is next.
    James
    Jun 2004
    Springfield Mo
    Default keyhole tool-path
    My keyhole tool-path is a thin rectangle 2 x .01 inches
    You can start in one corner and have it cut the rectangle slowly perhaps .1 IPS
    I go about .3 inches deep. Practice in MDF.
    I like the keyhole bit from Home Depot it has two flutes rather than one. Go too fast and they break for sure. Vac the dust as you go.
    http://www.homedepot.com/p/Diablo-25...0104/100660656
  1. T-Slots
    By phardy79 in forum ShopBotter Message Board
    Last Post: 04-02-2013, 09:42 PM
  2. Flatpack Slots and Tabs
    By zorlack in forum Archives2008
    Last Post: 10-09-2008, 11:09 AM
  3. Biscuit Slots
    By bakerkr in forum Archives2007
    Last Post: 04-19-2007, 10:33 AM
  4. How to cut slots in white oak without burs??????
    By woodesign@sonmedia.com in forum Archives2004
    Last Post: 01-27-2004, 09:20 PM
  5. Cutting .028 slots
    By srd1@bright.net in forum Archives thru 2002
    Last Post: 02-04-2001, 07:17 PM
