Results 1 to 5 of 5
Thread: What is a V-Groove Bit in Fusion 360?
    Mar 2016
    Silicon Valley
    Angry What is a V-Groove Bit in Fusion 360?
    V-Carve has a good sense of what a V-Groove Bit is when you choose Engrave options and see "V-Bits" as a tool type.
    In Autodesk Fusion 360 it isn't so clear. In the CAM space when I choose 2D, Engrave I get asked for a tool type. I had originally defined my Whiteside V-Groove Bit #1500 as a Counter Sink, but when I choose an engrave path using it I get a tool error. I'm going to redefine the tool as a Chamfer Mill to get around the error message, but I don't get the sense that a V-Groove Bit for Engraving is really a Chamfer Mill tool.
    Has anyone done engraving using Fusion 360 figured out how to define and use V-Groove Bits?
    thanks,
    Stephen
    Apr 2016
    To deal with the surprising lack of Vee bits, I created a tool from scratch and saved it in my personal library of tools after entering in all its dimensions carefully. You can start with a chamfer mill which is probably the closest thing in the Autodesk library right now (Sept 2016).
    Aug 2012
    Victoriaville, QC, Canada
    I recently came by a comment from another user of Fusion that defined his V bits with from a countersink type of bit with a zero size tip (or whatever tip size you have).
    Jan 2016
    Phoenix Arizona
    Yes, moving to Fusion 360 from v-carve for engraving was frustrating. I have made a screencast video with my technique to get acceptable results. I'm grateful they finally added the engraving toolpath, it was nearly impossible before that.
    Link to video:
    Aug 2012
    I was wrong (see my previous post). Fusion doesn't like creating an engraving toolpath using a countersink type of bit. I was able to do it with a chamfer type bit - so I changed my tool database accordingly and it worked.
  1. Fusion 360 Shopbot Tutorial
    By tomdubick in forum ShopBot in Schools
    Last Post: 11-19-2017, 03:19 PM
  2. Importing Fusion 360 into Aspire
    Last Post: 06-26-2016, 01:49 PM
  3. XY Fusion 360 weirdness
    By Riptide369 in forum Autodesk Fusion 360
    Last Post: 06-02-2016, 03:44 PM
  4. Fusion 360 videos
    By bill.young in forum Autodesk Fusion 360
    Last Post: 03-05-2016, 12:52 PM
  5. V groove bit
    By Greybarn in forum ShopBotter Message Board
    Last Post: 11-14-2010, 07:50 PM
