Results 11 to 20 of 27
Thread: Dust collction
    Aug 2013
    Clayton, NC
    I have a Jet 1100, it's 1 1/2 HP, only run on the CNC machine, and does fine job picking up dust. I've cut Max-Metal (aluminum composite panel - aluminum on each side and HDPE core) and it picked up alot of the chips but not all.
    A cyclone is a must, when I first set mine up and learning, I'd mess up tabs and the small pieces would get sucked up DC and BAM!!! hit the blades. I installed a garbage can cyclone lid in line and now when I make a mistake the large parts go in the garbage can and nothing hits the fan blade.
    Jet has a new model (not sure if it's out yet) that has the cyclone built in.
    Daniel E.
    Porter Cable Router
    Vacuum Table w/ 2 Fein vacs
    Aspire 9.0
    May 2016
    What is this a thein separator and where do u get one. Also. How did u install the cyclone on existing one
    Do a google search for Thein Separator and you will see how to construct one. Mine is the the kind that sits on top of a barrel I used wiggle wood to form the outer shell
    They go inline before your vac.
    For 1-5hp vacs look at these.
    I have two of their small ones for the Desktops and it keeps the vacs filter so clean that I have a very constant vac and no filter cleaning Love them!
    http://www.oneida-air.com/inventory....-E5F28583241B}
    Need to get one of these for my Delta in garage with my larger tools.
    May 2016
    Ok excuse my questions but this whole dust collection is new to me.. Here is what I have been looking at
    http://www.amazon.com/Shop-Fox-W1823...5%3A2470955011
    http://www.amazon.com/SHOP-W1687-3-H...5%3A2470955011
    http://www.amazon.com/Jet-DC-1100VX-...5%3A2470955011
    That shop fox has alot of CFM for the money shouldI get that and add a seperator?
  6. #16
    Collector on built in cyclone model seems small to me.
    Double bagger is same model I use for cnc and big slider and it could easily handle more.
    Guys have discussed fine microns getting clogged easily and losing pull as a result but I have never used one.
    You can add your own cyclone and have it drop into a trashcan easily. Mounted with a bracket on the wall means you just pull the can right out for quick changing and less hassle with the bags.
    http://cycloneseparator.com/
  7. #17
    May 2016
    If Put a cyclone on it do I need a double bagger or would this work? So if i understand correctly the cyclone helps store some of the larger pieces that go through? so say if something accidentaly got sucked up it would drop in it instead of going through impeller?
    http://www.amazon.com/Shop-Fox-W1666...5%3A2470955011
  8. #18
    Feb 2013
    River Fall WI
    You need the fine micron filter, if you do not have a great filter you do not have a dust collector you have a dust mover and unless you are moving it outside you are slowly killing yourself.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Aspire 8.5, Creo 3.0
  9. #19
    Sep 2008
  10. #20
    May 2016
    The dust collection will be outside while running.
  1. Dust Skirt and Dust Collection
    By upsman in forum Assembly & Maintenance
    Last Post: 02-23-2016, 09:21 PM
  2. A to Z dust gate switch & new Dust Boots
    By david_beede in forum Variations & Modifications of ShopBots
    Last Post: 03-05-2012, 02:31 AM
  3. A to Z dust gate switch & new Dust Boots
    By david_beede in forum Folder 2012
    Last Post: 03-03-2012, 12:39 PM
  4. WHAT DUST
    By coach in forum Folder 2010
    Last Post: 01-11-2010, 10:16 AM
  5. Replies: 7
    Last Post: 07-17-2008, 03:38 PM
