Results 1 to 4 of 4
Thread: Z-Axis migrating downwards
    Nov 2011
    Earth
    Default Z-Axis migrating downwards
    Hi there, have a odd problem, I set my z-axis depth to a specific figure and it has been cutting absolutely fine for years but now all of a sudden, it's migrating downwards while the shopbot shows the depth isn't changing.
    For instance, I was cutting out a piece of wood that's 20 mm thick in two passes without issue, now, on the single pass about half way through it's already cutting into the sacrificial board (beyond 20 mm deep) while the shopbot software continues to show 10 mm depth.
    Something is no longer maintaining height control on my ShopBot Desktop as it's cutting through material. I've re-zeroed the z-axis using the plate, that's always perfect, it's when cutting that it seems to go down.
    Founder of CNCKing.com (Project files for your ShopBot Table Router) and CNCROi.com (Custom CNC Shop)
    Garland Tx
    If it’s an Alpha, check to see if your resolution multiplier has chanced…
    This number changes the resolution between moving and jogging. When wrong on the Z axis, retract moves are usually jog moves while plunging isn’t. consequently, the Z axis can work its way down, yet read correctly.
    cnc routing, portland or
    fist thing to check always is the collet when bits slip the collet usually needs replaced. I usually can feel it takes turning to tighten the nut. you can also mark the bit shaft right at the collet and see if thats changing
    Nov 2011
    Earth
    BINGO, that was the problem! Thanks knight_toolworks!
  1. cutting a wave shape in the z axis along x axis?
    By sidofengland in forum ShopBotter Message Board
    Last Post: 09-02-2014, 04:20 PM
  2. Migrating Zero
    By bandphillips in forum ShopBotter Message Board
    Last Post: 12-06-2013, 11:15 PM
  3. switching Y axis onto A axis, How?
    By Fixed4that in forum Indexer
    Last Post: 10-22-2010, 04:15 PM
  4. Replies: 22
    Last Post: 12-08-2004, 10:10 PM
  5. Setting Y-axis square to X-axis
    By Gerald D in forum Archives2003
    Last Post: 11-22-2003, 11:41 PM
