Help!
I'm using Fusion 360 to design my model and then switching to the CAM workspace to define my toolpaths. When I use the post processor to create the .sbp G-Code to use in ShopBot is when I run into my problems.
I manually set the X and Y position to the front left corner of the Shopbot Desktop. When I run the part file I hit the limit switch since it is trying to align to an X and Y that is not on the cuttable surface.
When I switch to preview mode in Shopbot 3 I can see my model is off the cuttable area.
When I use V-Carve (which is much easier) I see that V-Carve has the ability to set your X and Y position in one of the 4 corners.
In Fusion I think this is defined in your sketch planes, but I could use any insight in how Fusion 360 communicates this to the Shopbot Post Processor.
