Results 1 to 6 of 6
Thread: Unable to change spindle speed
    Aug 2015
    Grants Pass, Oregon
    Default Unable to change spindle speed
    Spindle speed is not changing on our PRS Standard with 2.2 hp spindle. The only post processor options we have in VCarve Pro are what you see below. I searched through the forums here and somebody mentioned that the post processor with "ShopBot Arc (inch)w/speed(*.sbp)" as the option that allows for automatic speed changes. We have VCarve Pro version 8.014
    Thanks in advance for your help with this!
    David
    www.gphsmanufacturing.org
    Aug 2015
    Grants Pass, Oregon
    As if I didn't sound ignorant enough, I cannot notice a rpm change when running the spindle warm up routine either. Unless it is such a subtle variation in pitch...can't imagine that it cannot be heard.
    Do you have the VFD/spindle rpm USB controller hooked up and if so, do you have the spindle control tool/program running (Tools/spindle rpm control). Click in the rpm window to apply the appropriate settings for your VFD/spindle. If you do have this all in place, can you change the rpm by clicking in the rpm window and entering a new value. The TC inch post will control rpm.
    Aug 2015
    Grants Pass, Oregon
    I'll give your suggestions a shot as soon as I get back to work. Thank you Scott!
    Aug 2015
    Grants Pass, Oregon
    What a difference a new day makes. I got in to work this morning and started the spindle control program and I was able to change speeds by entering new values. When I took a look at the rpm window, I did not have the spindle control set to open when sb3 started up. Ran the warmup program and everything works great!
    Thank you for your help Scott!
    Glad to hear it!
  1. unable to control rpm for spindle
    By JMC Design & Fabrication in forum Other
    Last Post: 02-27-2015, 05:29 PM
  2. Pause file to Change (MS) speed
    By airroots in forum ShopBot Control Software v3
    Last Post: 12-07-2011, 10:16 PM
  3. Spindle RPM change lag
    By srwtlc in forum Troubleshooting
    Last Post: 11-14-2011, 04:37 PM
  4. How to change the up/down speed adjustments?
    By sam in forum Archive2008
    Last Post: 05-13-2008, 11:38 PM
