Hi,
I work with an old shopbot (48x96", with a V201A chip) that has been doing strange things. Until recently, it was running off an old Windows XP computer (with 512mb ram) which would run out of ram and cause problems ( it would drift in X or Y axis between cuts, during cuts, etc), so now we've switched to a windows 7 computer with 16GB RAM, and new problems have appeared. I've posted 2 videos as examples of this 'stutter'. The machine occasionally will begin stuttering violently as it moves and stops and moves again rapidly, as if the signal is garbled. I have always hit the stop button quickly for fear of it causing damage.
It happens intermittently, I can't figure out any variables that are always present. the first video shows it happen straight from the moment I press go, it's moving up in Z and away from me in X as it heads toward the start of a cut, or trying to at least. The router off so you can hear the machine. Other times it has happened at a specific point during a multi-pass cut, after finishing a cut while returning home, and it's even happened while moving the machine with the arrow keys, not running any cut file.
I've read a bunch of other posts and I'm sure the solution I need is there somewhere, but I'm too new at this to know what's relevant!
Here's what I've tried so far:
- plugged control box into USB 2 hub with nothing else attached
- tried cut files from fusion 360, as well as old files made on part wizard on old computer
- tried grounding the machine a little (single wire connected to X rack, waiting for go ahead to buy wiring, and properly ground)
- re-installed firmware on control box
I've read the pdf on properly grounding the machine which I will do once I get the go ahead, but the machine has been used as is for 5+ years in the same location without being grounded before.
I know this is probably not enough info to diagnose, but I'm hoping someone can lend me some insight and help me narrow down what to be looking for.
Thanks for any help you can offer!
