If anybody can tell you what the problem is Gary can do it. Keep in mind that if your indexer is mounted in the X axis then your Y axis is converted into degrees (360 degrees get's you one rotation)
Not sure i understand this statement "When I create a simple box I get the boot" you can't create a box on the indexer, so like Gary says post your design and maybe a better explanation of what you are trying to do would help us help you.
Words of Wisdom:
