Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: New shop ideas
    Jul 2014
    Bell, Florida
    Default New shop ideas
    Hi all,
    I am getting ready to build a new shop and wanted to get ideas - seen other post like this and learned a lot, so would like your input.
    So far I am looking at a metal building, concrete floor, spray insulation.
    I am in Florida so no floor heat will be needed.
    Think I am settling on a 40' x 100' x 14' with a 2:12 pitch
    Was thinking a 16' awning down one side but now not so sure.
    Think I want to be able to drive through the building across the 40'
    I am in a 24' x 32' two story building we built in 96 and it is real tight, I build RTA and custom cabinets along with custom furniture. Some equipment includes 4x8 cnc, 24" sander, table saw, shapers, 13 & 15 & 20" planers, band saw, small lathe and such.
    Below is a rendering of a possibility
    Thanks in advance
    Tim
    Tim Lucas Custom Woodworks
    www.TLCW.us
    Feb 2015
    NC, USA
    Not sure about everybody else but I find myself always wishing I had more drive in doors, lots of drop down power and air!
    Jan 2015
    Palm Coast, FL
    Things that I have found useful or wish I had:
    Three phase power.
    Spray booth/dedicated finishing area.
    Empty space for assembly and staging while waiting for pick up/delivery.
    Space for a 4x8 workbench in front of the CNC and directly behind a roll up door. Slide sheets off the truck onto the workbench and then onto the CNC. I have a large Kreg workbench on castors and it works great.
    Insulation and air conditioning
    PRS Alpha 96-60 ATC
    Aspire 8.5
    eCabinets with ShopBot Link
    Jan 2008
    I have a high ceiling / clearance and it sure is nice when swinging 'stuff' around. What I wished I had in my 40x50 shop is 'Spray booth/dedicated finishing area". Russ
    AKA: The Train Guy
    Jan 2015
    Houston Texas
    That's an impressive setup with all the PVC on the walls, clean layout
    Choose a job you love, and you will never have to work a day in your life.
    Jul 2014
    Bell, Florida
    Quote Originally Posted by willmorgan View Post
    My son and I were talking about drop down air last night and I was think only one or two drops over an assembly table, will have to consider more, thanks
    www.TLCW.us
    Jul 2014
    Bell, Florida
    Quote Originally Posted by Keith Larrett View Post
    Three phase power.
    Thanks Keith, I was thinking of putting the CNC in a back corner but now will bring it close the drive through area, planning on spray foam insulation and A/C
    www.TLCW.us
    Jul 2014
    Bell, Florida
    "I have a high ceiling / clearance and it sure is nice when swinging 'stuff' around. What I wished I had in my 40x50 shop is Spray booth/dedicated finishing area". Russ
    I have always liked looking at pics of your shop - My side wall will be 14' and should be 17' in the center, hope that will be enough - Yes I have a dedicated spray area now and will in the new shop also
    www.TLCW.us
    Tim,
    If monolithic slab, then a thermal break on the outside, if small frost wall, then thermal break on inside of frost wall. It isolates your slab/sub slab earth and gives you a lot of thermal mass and will save you cooling costs.
    Russ,
    Did you run any power under the slab?
    Does your 8' ply wall go all around? Great for shelving/tools/vac runs/ad infinitum
    Love how most of your work surfaces are the same height as your trolleys.
    Scott Plaisted
    2013 Desktop/spindle/VCP 9
    Jul 2014
    Bell, Florida
    Tim,
    Russ,
    Scott, not sure I understand - what would be used as a thermal brake? we just put a moisture barrier (plastic) then concrete
    www.TLCW.us
  1. Need some ideas
    By cowboy1296 in forum Project Ideas
    Last Post: 11-05-2015, 02:20 PM
  2. Any Ideas?
    By dvmike in forum Troubleshooting
    Last Post: 07-13-2011, 02:45 PM
  3. Any ideas?
    By boxbuilder in forum Archives2006
    Last Post: 06-11-2006, 02:37 PM
  4. Ideas
    By toktokkie in forum ArchivesSchools
    Last Post: 02-28-2006, 04:59 PM
  5. New ideas
    By wiese in forum ArchivesSchools
    Last Post: 08-23-2003, 10:01 AM
