Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Using my asm911aadc2.65v servo motor to make timing belt pulleys
  1. #21
    Mar 2009
    n/a, Vancouver BC
    Here is the gearbox unit assembled and ready for testing on Tuesday. I have a friend who has managed to get another driver and stepper combo running off of an Arduino board. We are just getting that all set up to drive the indexer around 10 times from that to check the actual ratio of the gearbox so the shopbot software multiplier value will be accurate.
  2. #22
    Mar 2009
    n/a, Vancouver BC
    The indexer is working beautifully, controlled by a little arduino. After 25 revolutions (625 of the stepper) the mark lines up. There appears to be zero backlash, I will need to confirm that. Next step is to mount a 36 inch disc in the nova chuck and then perform the same test. On low resolution setting of 500 each pulse sent to the stepper results in a rotation of 0.0072 degrees, and on 1000 results in 0.0036 degrees. This is all before alpha stepping. I expect it will perform better with the shopbot control and software. Can't wait to make some sawdust with this thing...
  1. Adhesive for timing belt
    By tlempicke in forum Techniques for Cutting, Drilling, Machining
    Last Post: 01-16-2011, 07:41 PM
  2. Timing Belt Style (Gear) Reducers Experience
    By gerryv in forum ShopBotter Message Board
    Last Post: 11-23-2010, 01:58 PM
  3. AC Servo system
    By gc3 in forum Variations & Modifications of ShopBots
    Last Post: 07-10-2010, 07:55 PM
  4. Indexer-stepper versus servo gear ratio
    By pjohnsonj in forum Indexer
    Last Post: 01-20-2010, 03:39 PM
  5. Belt, we don't need no stinkin' belt!
    By gpari in forum Archives2007
    Last Post: 10-16-2007, 12:18 AM
