Originally Posted by
Joe Porter
Nick, the post processor choices are in the drop down list under "Save Toolpaths" on the toolpath side of the screen. At the top of that pane is also a check box to "Output all visible toolpaths to one file", that is assuming you are using the same tool, which I think you are. I think most of us use the ShopBot, arcs in. with a standard machine and the Alphas use the PP "...with speed" added into it. I also noted that your cut speed or "Feed" is really slow, like 2.5" per Minute. I think you mean per Second? that's 150" per minute, which is a little fast if you have a Standard. Your plunge speeds are also set at .6" per minute. I see your design is in the lower left corner of the material, but the toolpaths are in the center. I don't know how that happened. Finally, the outer circle has a duplicate vector on top, that should be eliminated. I hope this has been of some help...joe
