Originally Posted by
tlempicke
I see from your pictures that you are using a lot of screws to hold things to your spoil board. Same here until I discovered Raptor nails and the Omer nailgun. The nails are plastic and strong as all get out, in tension. They will shear cleanly if you give the item that they are holding a good whack with a mallet.
The beauty of this is twofold. First you can put something down rapidly and remove it rapidly. Second if you hit a hold down with the cutter you will never know about it. Your bit just cuts the nail and goes on its way. I have even used this feature to hold stuff in an area where there was cutting happening but later would be concealed.
The nail Gun is a specially built thing that costs about $350. But the time and effort it saves will pay for itself in short order.
Do a search on this forum. Lots of talk about this in the past.
