Results 1 to 6 of 6
Thread: Zipbolts
    Jan 2015
    Palm Coast, FL
    Default Zipbolts
    This is probably more cabinetry related than CNC, but maybe it can help someone out. I've been using Zipbolts to clamp long pieces of plywood together.
    Primarily counter tops, but also other pieces that are normally difficult to clamp, long sections and sections clamped at an angle. I cut templates to fit the Zipbolts on the ShopBot and use biscuits for alignment. The Zipbolts are tightened with a 5mm hex in a drill so the clamping goes very quickly. Much quicker and easier than the connectors that require a couple of wrenches to tighten.
    The only disadvantage is, because the clamps are on one side, there is a tendency for the work to bow slightly, so it needs to be clamped flat. I take care not to get glue on the template and then once the glue is dry, I remove the template and screw a scab piece of ply over the joint.
    If the Zipbolts need to remain in place, then I use the mini Zipbolt as they are less than 3/4" high. If I'm just using them as temporary clamps, then I use the 35mm Zipbolts. They are just over 3/4" high, so they stick above the ply a bit.
    http://zipbolt.com.au/product-items/...500-81mmx35mm/
    http://zipbolt.com.au/product-items/...800-6mmx100mm/
    I get the Zipbolts from Hafele, but they are available elsewhere as well.
    I've attached a DXF of my template. After cutting on the CNC it needs to be cut in half on the table saw.
    Attached Files Attached Files
    PRS Alpha 96-60 ATC
    Aspire 8.5
    eCabinets with ShopBot Link
    Sep 2012
    Blaine Mn
    Very interesting, thanks Keith. I can see uses for this far beyond cabinetry for the rest of us. This is why I look at every thread, often you will see something or an idea that can be adapted to whatever discipline you practice. Thanks Gene
    Delray Beach, FL
    For temporary holding like that I generally reach for pinch dogs.
    Another handy item in the tool kit is a set of spring miter clamps.
    When using the bolt system I mostly use flip bolts now. No tools needed to tighten.
    One thing for sure-you can never have enough clamping devices.
    Jul 2011
    Timmins, Ontario, Canada
    We use the line of Zipbolts for all our railings work. They really shine when attaching various rail to each other and to newel posts.
    I spoke to the company at the IWF show and they gave us a big bag of new product in the line to try out. I get them through Richelieu Hardware up here.
    Jan 2015
    Palm Coast, FL
    Quote Originally Posted by bleeth View Post
    So many clamps. So little time.
    PRS Alpha 96-60 ATC
    Aspire 8.5
    May 2007
    Elite Wood Designs, LLC, Social Circle GA
    Never used Zipbolts before. Thanks for the heads up cause they look real beefy. I've just used the flipbolts before from Fastcap and really like them too.
    Jay
