Results 1 to 10 of 14
Thread: table base coordinates
    May 2001
    Lewisburg, Pa
    Default table base coordinates
    I need some help understanding table base coordinates vs using the C3 command to reset home using proximity switches. I would like to have the C3 command move to the move to the ZT based 0,0 after finding home from prox switches. Is there a way to have C3 move to some offset location or must I physically move my prox sensers to move that location.
    Thanks for helping an old feller out.
    Jan 2016
    Phoenix Arizona
    I'm at home, so I can't play with the code and give you a complete answer, but there are a few ways you could make that happen. Here are a couple that pop into my head:
    1. If every time you do a C3, you "ALWAYS" want it to move to a specific coordinate afterwards, you could add that line to the end of the C3 file (M3 x,y,z)
    2. Another option, if you just want to have a simple keystroke shortcut to move the cutter to a predetermined location would be adding your own custom cut file. Then all you would have to do is press CC+your custom # to run that file after you completed your C3 routine.
    Delray Beach, FL
    Not sure what you mean by "move to the ZT based 0,0.
    Your prox locations are the movement limits and are typically a little away from where the machine would hit the stops for safety reasons. Setting up your C3 home can be done manually by entering in any positive offset number you want and is usually done for the corner of your spoilboard, which is also used to align parts. So you find that corner manually with keystroke moves and a pointed bit, hit z2 to set both at zero, and move slowly till you hit your prox switch and record the distance. That's the number you want in your settings. I believe there is now a built in program that you can run during set-up to do this for you, but as an "old timer" I've never used it. I find it easier to make those little adjustments til I'm satisfied I'm at the corner of the board properly in relative mode of moving so if I want to move, say 1/32 or so I enter .003 instead adding or subtracting to get the next location. You could also just press zx (if finding the x 0 sweet spot after each move til you get it dialed in.
    May 2001
    Lewisburg, Pa
    Thanks for your help. The problem started when I upgraded to latest shopbot software. Both limit checking and the C3 command were different. I solved problem by writing short routine that I can run afterC3 to go to the old home position. I guess I should not have upgraded shopbot program and stuck with the old tried and functioning version.
    Jan 2016
    Phoenix Arizona
    Quote Originally Posted by jerryk View Post
    I'm in the shop today so I can be a little more precise with my comments and advice. Did you try going through the Shopbot Setup under the Tools Tab [TS]?
    May 2001
    Lewisburg, Pa
    Thanks Brady,
    This is exactly what I needed, and automatic at that. I am now back up and running.
    May 2012
    St. Paul, Minnesota
    I found this thread just exactly what I needed to read after a PC and SB3 software update. I'm still having problems with my Z axis being wrong though. When I run a C2 and zero with my plate, it thinks its at 1.0" in the control software, but when I put a tape measure on it, it's only sitting at about .375". Initial thoughts were that maybe I have a variable set wrong somewhere? I have Vexta stepper motors. Model ASM911AA on both my x and y axis' and a model ASM98AA-T10 motor on my Z axis.
    Anyone have a similar issue after a PC and software update?
    Nate Sirek
    Operations Manager;
    Shop Fabrication Manager
    House Partners Inc.
    West Saint Paul, MN
    Shopbot 48 x 96 PRT Alpha
    220v 18000 RPM HSD Spindle
    4 Zone Vacuum Table, 7hp Spencer Re-Gen Blower
    Cabinet Parts Pro
    10 Years Experience in a cabinet and counter top fabrication shop. CNC Newbie.
    Apr 2007
    Marquette, MI
    Nate...
    Have you adjusted the unit values on the Z axis for the 10:1 motor?
    Gary Campbell
    GCnC Control
    GCnC411(at)gmail(dot)com
    Servo Controller Upgrades
    Albert Einstein
    May 2012
    St. Paul, Minnesota
    Gary,
    No I have not. I've been doing some casual SB manual reading about this though. What would the values change to for the 10:1 motor? X and Y values are set to 1273.2395 (for 25 tooth pinions). Z is set to that as well but I cant see the Z pinion to count its teeth but from what I can remember it has a different ratio then the x and y motors. Not exactly sure what the value should be though. Thanks for your help!
    Nate Sirek
    Operations Manager;
    House Partners Inc.
    West Saint Paul, MN
    Cabinet Parts Pro
    Apr 2007
    Marquette, MI
    Nate..
    I think that if you do a little more checking you will find that the "1273" number is for 20 tooth pinions.
    I assume you have a 25t pinion on your Z, if so thy 4138.0285 as a unit value, if its a 20 then use 5172.5357
    Gary Campbell
    GCnC Control
    Albert Einstein
  1. rotating table coordinates
    By artbot in forum ShopBotter Message Board
    Last Post: 08-25-2012, 02:40 PM
  2. A large table base
    By bob_s in forum Folder 2010
    Last Post: 12-19-2010, 08:53 PM
  3. Vac table - base board ?
    By dubliner in forum Archives2007
    Last Post: 08-21-2007, 08:06 AM
  4. Table base coordinates in relation to indexer?
    By myxpykalix in forum Archives2006
    Last Post: 11-15-2006, 02:37 AM
  5. Table coordinates out of whack?
    Last Post: 11-14-2006, 04:58 AM
