Had sloppy circles and lettering looked off, so replaced my gears. in my efforts to check movement in the carriages I noticed very little, but a "tic" in each side of the X. after messing with it a bit I pulled the motor out and noticed that the "tic" seems to come from the gear/ motor spindle connection. both parts are keyed, and that is engaged. so is that amount of play acceptable?
I would guess that the movement is between 1/64 and 1/100. you can notice it if you hold a block of wood against the front of the gantry and do the "tic"
