Results 1 to 10 of 13
Thread: ShopBot (arcs)(inch)(*.sbp) versus ShopBot Arc (inch) w/speed (*.sbp)
    Aug 2016
    Pacific NW
    Default ShopBot (arcs)(inch)(*.sbp) versus ShopBot Arc (inch) w/speed (*.sbp)
    (Aspire 8.5): Can someone please explain when one would want the post processor 'w/speed' versus the one without? Seems like there would be a difference else why are there two choices? Thank you.
    Garland Tx
    If you have a spindle that allows speed control within the program code, use the “with speed” version… the speeds you specify in your bit definitions will apply. None of the PC routers qualify…
    Aug 2016
    Pacific NW
    Thank you, Steve, that sounds great! I do have a spindle (Desktop MAX) with speed control (a box with knob control that I have only used when warming up the spindle), but until I learn more, I have just used the default settings that seem to populate the fields when I choose a bit. Sounds like I will be using the 'w/speed' post processor from now on. When I just used arc inches, was it ignoring the speed in the bit definitions? Many thanks.
    Garland Tx
    Carolina…
    Someone with A desktop MAX will have to chime in here… Just because you can manually change the speed with a knob, doesn’t necessarily mean that the spindle is communicating with the computer… I don’t know if the MAX does.
    If it's like the Desktop Carolina, then we have to manually adjust the VFD.
    Tech told me once that the Desktop controller and the VFD don't speak the same language.
    But that was Desktop, and 2 yrs ago.
    Easy enough to make a test file with 2 different RPMs and save using each to see if you can hear the difference?
    Aug 2016
    Pacific NW
    That sounds like a good test plan to try, thanks
    Apr 1999
    Rock Hill SC
    If you have spindle control of speed from the SB3 program you have to have a small circuit board installed in your VFD. That circuit board has a USB plug that plugs into the control computer.
    Aug 2016
    Pacific NW
    Quote Originally Posted by tlempicke View Post
    Thank you, I partially understand, I think. I can't look at my D Max for a few days. Pardon my ignorance, is the control computer part of the CNC innards (housed at one end of the machine), so look for a USB plug from the VFD to there? Or is the control computer my laptop and I would plug in there? Guessing inside the CNC innards. Sorry!
    Apr 1999
    Rock Hill SC
    In mine the circuit board is inside the VFD and a second USB plus goes to the control computer.
    Control Computer would be your laptop Carolina.
  1. VectrIc Aspire shopbot arcs inch post processor MISSING...
    By johnh in forum ShopBotter Message Board
    Last Post: 02-03-2015, 12:52 PM
  2. Z at 1 inch
    By Richardksmith in forum ShopBot Buddy
    Last Post: 05-17-2014, 08:49 AM
  3. 1/8 inch bit source
    By toddmaci in forum ShopBotter Message Board
    Last Post: 12-03-2009, 10:06 PM
  4. 1/2 inch to 1/8 inch collet
    By wemme in forum Archives2006
    Last Post: 07-28-2006, 01:40 AM
  5. FYI: 2 inch Ultraboard
    By diapowder2000 in forum Archives2006
    Last Post: 05-01-2006, 08:21 PM
