Results 1 to 9 of 9
Thread: pocket screws
Hybrid View
    Sep 2011
    New Hampshire
    Default pocket screws
    Has anyone tried the pocket screw feature yet?
    Jan 2009
    Chapel Hill NC
    I missed that, where is it found?
    Nov 2016
    Dale, IN
    To use pocket screws, you must have the latest version installed found here http://www.thermwood.com/updates_shopbot_link.htm. You must have a 3/8" tool set up and checked for Pocket Screw Rout. You must also have a 5mm tool set up to drill and from the drop down box one of the options selected. If you intend to use the 3/8" tool or 5mm tool for other operations, you must set it up again with those boxes unchecked. When the boxes and options are checked, they are only used for those pocket screw operations.
    That being said, there is a current bug in the new version. It inputs an M31 that is not recognized by ShopBot routers. You can simply click OK and it will move past the error. It will corrected for the next version.
    -Clint-
    Sep 2011
    New Hampshire
    Thank you for the reply. That was my problem I use a 3/8 and 5mm but when I checked the pocket screw box the software couldn't find the tool to do other operations. I assume I will set up another 3/8 and 5mm with only the pocket screw box checked after the tools I use for cutting and pocketing.
    Nov 2016
    Dale, IN
    Quote Originally Posted by 2006prt View Post
    Correct. You'll set up the tools in their regular operation, then set them up again in later operation to do the pocket screw work.
    -Clint-
    Sep 2011
    New Hampshire
    I tried it again with the tools set up as described and could not get it to work. has anyone been successful with this feature?
    Jul 2014
    Bell, Florida
    I haven't tried it yet
    Tim Lucas Custom Woodworks
    www.TLCW.us
  1. Screws for HDPE joinery
    By Josh Beckmann in forum Product/Supplier List and Requests
    Last Post: 10-13-2015, 09:40 AM
  2. Screws, and Parts
    By genek in forum Project Ideas
    Last Post: 06-30-2014, 11:48 PM
  3. Anyone know what these screws are called?
    By SterlingDevelop in forum Product/Supplier List and Requests
    Last Post: 04-21-2014, 12:13 PM
  4. Plastic Screws
    By trakwebster in forum Archives2006
    Last Post: 09-12-2006, 11:48 AM
  5. Acme Screws for X/Y/Z
    By ecnerwal in forum Archives2004
    Last Post: 07-01-2004, 01:35 PM
