Results 1 to 10 of 15
Thread: Rigid vacs
    Feb 2013
    River Fall WI
    Default Rigid vacs
    Anyone out there using Rigid vacs for your vac table?
    One of our feins just melted and they do not make them any more.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Aspire 8.5, Creo 3.0
    cnc routing, portland or
    not a good idea they are not up to the job though they are much better as a basic shop vac then the fein is. If you can only go 110v I would get two of the fein type motors and make a black box out of them they will be quet and they are about 160.00 each.
    Feb 2013
    River Fall WI
    That would be nice but I do not have time to make anything.
    I see the fein I and II have the same motor, 1100 watt motor that delivers a 151 cfm flow rate and 98.4 inches of water lift.
    The specs on the III were
    Nominal Power: 1,200 Watts
    Air Flow: 126 CFM
    Static Water Lift: 99"
    I'm thinking of getting a I and letter rip....
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    I bought a 1 for house cleanup that was quiet. but it turned out to not have a huge amount of airflow can comes with with a wacky filter. then the power plugin stopped working. the 3 is the same as the older ones it just has variable speed.
    Feb 2013
    River Fall WI
    Where can you fined a 3?
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    looks like the 3 is gone the two is whats the new three I guess. if I went bac to vac I was thinking along these lines
    https://www.amazon.com/dp/B008600U1K?psc=1
    but this is the guy I would get still uses the round filter.
    https://www.amazon.com/Fein-9-20-25-...&keywords=fein
    Jun 2004
    Springfield Mo
    Default vac repair shop
    I went to a local vacuum repair shop and they had a used vacuum motor out of a car wash vacuum that worked great, they put new brushes on it...
    Mounted right under the table, about 40 dollars.
    What do you need a filter for. When I checked mine there was nothing in it after 8 years.
    Jasper, TX
    The ridged will work to get by but will burn out quick. Shop vac may last longer.
    Wish I had the bucks to get that Fein 9-20-25 Steve
    They've stopped making it, and the variable speed makes it Perfect for a Desktop, and I've been dreading getting one with a simple on/off switch.
    Dang....and a price 100-150 $ less than the last time I saw it
    I hope the new motor the Fein repair center stuck in for free(3 months short of the 3 yr warranty) holds out for a long time.
    Quietest shopvac I've ever heard, even at power level 5.
  1. what is MDO, where is Mr. Trupan, & who's got the best vacs?
    By God's Girl in forum ShopBotter Message Board
    Last Post: 10-26-2011, 02:54 AM
  2. Summit Vacs
    By Jerome in forum ShopBotter Message Board
    Last Post: 08-24-2011, 08:26 PM
  3. Fein Vacs
    By tracys in forum ShopBotter Message Board
    Last Post: 03-14-2010, 11:08 PM
  4. How rigid is the Buddy 48?
    By dingwall in forum Archives2008
    Last Post: 12-24-2008, 04:47 PM
  5. Fein Turbo III vacs.
    By gary_n in forum Archives2007
    Last Post: 05-05-2007, 03:43 PM
