Started off nice and simple.. No problems so far other than have a couple thou grooves from flycut tool only on right side X+ on spoilboard and some vibration when z axis goes up with vgoove tool..
first sign .....ehh its a start
what speed do you have your z set at. seems like i remember what appeared to be a vibration when it was set dead slow. but i am old and can be forgetful.
Nice compared to my very first cut, where I topped out Z and my spoilboard rabbet cut headed to China
Are all the spoilboard bolts tight? NC humidity might not be the same as yours, and MDF could have shrunk a hair, and you're noticing it on the right side?
There are certain combo's of Move/Jog speeds that set up resonance(my DT cuts noticeably worse at X,Y Move Speed of 1.3IPS, so I never cut at that speed...1.2 and 1.4IPS are fine).
Try moving around the table with your MS at various speeds in X,Y,Z and note down any rougher/noisier speeds and avoid those.
Also, maybe change Z MS to .5IPS for the first month or so until you get used to it? Sometimes a split second can let you hit the Spacebar Pause fast enough to prevent an Aw Sh** moment
If all speeds in Z vibrate or are noisy there is a solution and shout out, but maybe it's just that one speed.
Looking good
Lowered speeds and definitely better..will test it some more just to be sure...thanks..all bolts are tight..rechecked and flycut again and they are still there..very minimal but noticeable...maybe .003-.004..
