Since I can't post the code, here's at least the top part of the file. I'm using Shopbot version of V Carve Pro 8.514 with the Shopbot post proscessor, no mods.
'SHOPBOT ROUTER FILE IN INCHES
'GENERATED BY PARTWorks
'Minimum extent in X = 0.000 Minimum extent in Y = 0.000 Minimum extent in Z = -0.625
'Maximum extent in X = 12.000 Maximum extent in Y = 5.500 Maximum extent in Z = 0.000
'Length of material in X = 12.000
'Length of material in Y = 5.500
'Depth of material in Z = 0.625
'Home Position Information = Bottom Left Corner, Material Surface
'Home X = 12.000000 Home Y = 10.000000 Home Z = 1.700000
'Rapid clearance gap or Safe Z = 0.200
'UNITS:Inches
IF %(25)=1 THEN GOTO UNIT_ERROR 'check to see software is set to standard
SA 'Set program to absolute coordinate mode
CN, 90
'New Path
'Toolpath Name = V-Carve NS 60 1-4 010 tip Ons
'Tool Name = 1/4" 60* 010 tip Ons ENGRAVING 37-03
&PWSafeZ = 0.200
&PWZorigin = Material Surface
&PWMaterial = 0.625
'&ToolName = "1/4" 60* 010 tip Ons ENGRAVING 37-03"
&Tool =35 'Tool number to change to
C9 'Change tool
TR,18000 'Set spindle RPM
C6 'Spindle on
PAUSE 2
MS,0.7,0.4
JZ,1.700000
J3,2.351121,3.642589,0.200000
ShopBot Desktop 24x18
Spindle
VCarve Pro 8.5xx
ScottP Super Deluxe Spoilboard
