I have been reading several posts concerning issues w/ the newest control software versions, but I have not read anything which describes my situation. This past June I upgraded to 3.6.1. Since that time I have been having an annoying problem with the bot locking up.
At the end of everyday I park the spindle at 96,48. The next day I hit the "jog home" icon (or J2) to drive it back to 0,0. The problem is that 10 or so inches into its path home that bot stops hard and get "Shopbot Paused in Movement or File Action". If I look at the screen the control panel thinks its still moving to its intended destination and doesn't stop until it gets there. So I hit "Quit" on message box, then click on the jog home icon again to get it close to 0,0, then I have to rezero. Once this is done I seem to be good for the rest of the days cutting.
My prox. switches are turned off, no screen savers, the PC is not connected to the net, nor is it used as the main design pc. Nothing else is running. No wiring or physical changes were made after the software upgrade. All the usual questions Frank asks are in line.
One thing I read on the forum caught me eye but I am a little confused about it or if it really pertains to me.
"Shopbot Loosing Comm." Try- grounding wire from the PC chassis to the D-ring on the USB serial connection to the Shopbot Control Broad. This portion is what I don't understand- "D-ring on the USB serial connection to the Shopbot Control Broad"
If anyone has any suggestions to a possible cure I would be very appreciative. Thanks.
