Cutting Veneer
Anyone have experience with holding down and cutting veneer? I am going to do some marquetry and I have an Epilog Laser that I plan on using for most of the work, but I would like to use the Shopbot for lighter colored veneers.
This is the software I'm using.
http://www.amazoncanvas.com/
I did this by laminating the veneer onto an mdf substrate with a very light sprayed contact cement application and using a small bit (1/8 or 1/16R). After cutting the veneer it peeled off easily.
Although I didn't use one myself I understand a Donek Dragknife and hold down foot works well also.
- You may not post replies
- You may not edit your posts
Forum Rules
