Thanks everyone,,,, here is a quick reply concerning the question of play in the Z axis. I often check for play in my X and Y axis, by pulling/pushing on the X car, and on the Y car, but I realized I had never done that on the Z/spindle.
So just now, I pulled/pushed on the X and Y cars, and could not perceive any movement. When I pulled up and down on the Z car, which is a bit more awkward, I was surprised to see movement (and expect I pushed harder on the X and Y cars). So I measured and found I was able to pull up .006" and down .014". How bad of a reading is that?
And a long time ago, when I first set up my machine, I had used my dial indicator on a trammel to square up my spindle. And while I don't recall the numbers, I did post them here and people told me they were good.
As to the spoil board delaminating, that may well be the case. I am pretty sure I used Tightbond glue and I put weights all over the top of the table. But who knows, that was maybe 7 or 8 years ago. I'll set up a cross beam with a dial indicator and see if I can detect any deflection over any areas of the table center.
Thanks,,,,,,,,,, later,,,,,,,,,, Chuck
Chuck Keysor (circa 1956)
Columbo 5HP spindle
Aspire 9.0, Rhino 5
