Thanks Mayo and Joe:
Mayo, all 4 "double V" rollers have eccentric bushings, so each can be independently adjusted to get proper roller/track engagement. When I disassembled my Z plate, I removed only the two "double V" rollers on the right side, so I assumed when I reassembled everything, I'd just have to adjust the two parts I had removed.......... Wrong........ After reassembling, no mater what I did on the right side "double V" rollers could make , one of the "double V" rollers on the left side engage its V-track. So I wound up having to adjust the eccentric bushings on all 4 "double V" rollers. But based on the information Joe supplied, I probably had over-tightened the lower "double V" rollers 8 years ago when I re-assembled my Bot.
Joe, thank you VERY much for the interesting document on the Bishop Wisecarver "Double V" rollers. I had never even realized that the rollers could be used not only like in Shopbot's designs to ride on a single rail, but that they can also ride inside a 90 degree track..... cool. But MOST significantly was information they provided near the end, about adjusting the eccentrics. They said the adjustment should be made so that each "Double V" roller can me turned by hand/just slipping. Without any documentation, I had adjusted just to the point where I could NOT turn any of the 4 rollers by hand. And I very carefully snuck up on that adjustment, so I know it is not smashed down super tight. But knowing they should be able to barely slip is important, and I'll have to go back and fix that. THANKS AGAIN Joe!!!!!!, great information!!!
But that is as far as I got, as I had something to make (still not done) that doesn't use my Shopbot. But I'll have to go through and re-establish that my spindle is perpendicular to my table, which in the past was very tedious, requiring inserting thin brash shims, rechecking, reshimming,,,,,, And since I had to adjust all 4 "Double V" rollers, I have certainly thrown my spindle out of whack in at least one dimension.
And with my wavy table top, I'll have to lay a piece of plate glass on top of the table, and hope that rides out all the dips and waves of my table top, in the way that works out for my correct alignment......
On one hand, I'm sorry I'm so slow at getting this done, as I have needed to use my Bot one time. But having this new info from Joe will allow me to fix my over-tightening before I get into the spindle alignment.
Thanks again, Chuck
Chuck Keysor (circa 1956)
Columbo 5HP spindle
Aspire 9.0, Rhino 5
