Anyone know a good supplier for one? I want to put one on my vacuum table.
the only complaint about those is the cost. they are way overpriced for such a simple thing. if you want to save 300 make one out of a shopvac hepa filter and a wooden box.
I don't use any filter as my spoil board filters all the dust. I have been running my vacs for 8 years and they still look like new inside. I do reverse the air flow every so often to clean out the spoil board
I don't have a filter and I run a blower.
I'm not sure how anything could get into the plenum and into the vacuum tubing? The mdf spoilboard won't pass anything through but air.
I've often considered a vacuum filter but unless I'm missing something... how would anything get to the pump?
I have a blower with an inline filter. I inspect the filter regularly and have seen debris in the can pretty often. On one occasion there was a lot of debris. In that case I think it got there due to a miscut which cut to deep into the spoil board. However, if you are in the habit of screwing parts down into the spoil board I think you increase the chance of debris being pulled through those holes. For the amount I paid for the blower the cost of an inline filter to protect it, even if it seems overkill, makes sense.
PRS Alpha 96-60 ATC
Aspire 8.5
eCabinets with ShopBot Link
when I remove my spoilboard stuff gets in the pipes.
[QUOTE=knight_toolworks;195078]when I remove my spoilboard stuff gets in the pipes.[/QUOTE
When do you remove your spoil board? Do you remove it often? If not you can blow out the pipes
I use no filters either I run lighthouse motors I have always thought the spoil board was the filter. No problems in 8 years of use.
WWW.MillerMarineProducts.com
Proto Trak DPM CNC Bed Mill
Brand X Industrial router
Sharp SVL-2416SE-M VMC
