I'm trying to hookup a relay board (24V, 5 relays) to my 60x96 PRS Alpha and having the following issue. Whenever I connect a wire to one of the output terminals on the motherboard, it appears to turn the corresponding relay on (green light turns off) This happens regardless of whether the output is turned on in the control software. It actually happens even if the control software isn't running. The only way to get the green light to go off is to unwire it from the output.
Any ideas on what I'm doing wrong? Relay board is wired to ground and 24V.
