Results 1 to 10 of 11
Thread: Aspire or Shopbot problem?
    Apr 2012
    Illinois
    Default Aspire or Shopbot problem?
    I am running a large sign foam sign on my Shopbot PRT Alpha with a 5hp spindle. I am using a 1/8" ball tip bit at 175 inches per minute. The component that I am running is a 3d wood grain running in the X axis. The problem is that I am getting ridges running in straight lines on the Y axis. about a 1/8" apart along the entire length.
    Garland Tx
    Those are very authentic looking surface planer marks!
    The regular spacing would look like a mechanical issue… But I don’t know. Let’s see what the 3D guys say.
    If they don't show in the preview...90+ % of the time it's a machine problem.
    Use max simulation quality in the pull down, and we can at least eliminate one of the two.
    (NOT one of Steve's "3D guys
    It's not surface planer marks as you see the actual surface (top left, bottom) are above this wavy surface (you don't run sign foam thru a planer anyway). Depending on how you made your toolpaths (carved letters seperate from pocketing larger space, i'd say your stepover on this toolpath is too large. You would think the letters would show the same pattern but they don't.
    Words of Wisdom:
    Drop the motors away from the rack and roll it along the X to see if you can feel the very consistent 'bump'. Check the X v-bearings. When replacing the motors, make sure that they are adjusted up into the rack properly. Would seem to be a perfectly placed 'bump' in the motion back and forth on the X axis.
    Garland Tx
    Ha!, jack…I in no way was suggesting that they were surface planer marks… just that they were authentic “looking” marks! So, if you need to simulate Planer marks in foam, we just need to figure out what t28c34 is doing!
    I think Scott is on the right track with worn bearings…
    May 2011
    ny
    Probably something jammed in a roller groove I had that happen machining insulation foam the stuff got into the rollers.
    Dec 2008
    Diamond Lake, WA
    Agree with Brian. Looks like something jammed in the V-groove bearing. That's the only way I can see getting that very consistent pattern.
    Don
    www.dlwoodworks.com
    Apr 2007
    Marquette, MI
    I'm in for backlash in the Z axis. Adjust the pinion to rack or loose grub screw
    Gary Campbell
    GCnC Control
    GCnC411(at)gmail(dot)com
    Servo Controller Upgrades
    Albert Einstein
    Apr 2012
    Illinois
    Took a little slop out of the Z axis, but that didn't take care of it. With the power off, moving the X carriage I can feel some roughness in it. With the servo motors backed off, the carriage moves nice and smooth. Pulling the spur gears off I can see some wear in them. So I have new spur gears on the way. Ill try that out before I replace the racks.
