Results 1 to 5 of 5
Thread: Feed & Speed
    Jan 2014
    Miami, FL
    Default Feed & Speed
    Attempting to carve stars into a piece of Purple Heart
    using 60 deg 1/2 V-Bit
    RPM 14000
    What would be a good feed and speed
    thank you
    Feb 2013
    River Fall WI
    scott will tell you
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Aspire 8.5, Creo 3.0
    Overly optimistic Kyle
    Jerry,
    Haven't cut much Purpleheart in last 2 years, and you didn't say if it's a 2 or 3 Flute bit.
    What is size and depth of the stars?
    It cuts very similar to Bloodwood which I do more of.
    I've only ever cut it with .125 and .25" shank 2 flutes and engraving bits, but here's my database for the Celtic Purpleheart button.
    I think somebody who does bigger and more aggressive work will help more, but I'd probably test a couple stars on a piece of scrap at .7(IPS X,Y), .4(IPS Z plunge),15-16K RPM to start if it's a 2 flute, and keep the pass depth(if the stars are small) at .05" for starters.
    Ballpark guess though only if they're small stars....if tearout, lower plunge and increase RPM slightly.
    Hope this helps,
    Jan 2014
    Miami, FL
    Thanks for the info and guidance, The stars are small to get the scale correct for my max 24" desktop
    only 0.6945 tip to tip and shallow my Aspire 8.5 has the minimum depth of 0.196 to not have then truncated
    The female star's were cut successfully using several shallow cut to get to the max depth
    The male stars are getting broken up.
    Tried cutting stars, then cutting excess wood out
    Then the reverse did a pocket which left the stars ok in the form of star shaped pillars, no point flat top
    then tried to V Carve the pillars to form the actual star pattern
    In the end the stars were all broken and in pieces, have used 90 and 60 degree bits.?
    Jerry,
    Didn't realize you were trying to inlay the stars...if I were trying to inlay a field of stars I would VInlay it;
    http://www.vectric.com/support/train...us/vinlay.html
    It's capable of extremely fine detail and would keep the stars attached to the waste backing for clamping.
    In my pics, all this wood work was done with an Onsrud .25shank 60degree engraving bit with a .01"flat.
    I've read others are now using a 30 degree to make the fine details deeper for the inevitable sanding, and I'll try it on my next VInlay project.
    I'm hoping that's what you meant(Inlayed stars).
    LOTS of the threads on the Vectric forum about "VInlay" and "VCarved Inlay" if you do a search.
    Hope this helps...maybe show a pic of exactly what the project looks like?
