Results 1 to 10 of 11
Thread: Pressure foot
    Oct 2005
    Timberline, St .George
    Default Pressure foot
    I am looking into the purchase of a pressure foot for my spindle.
    I have inclosed a link to a pressure foot i found online.
    Just wonder if anyone had any experience with this type of pressure foot thanks .
    https://www.aliexpress.com/w/wholesa...sure-foot.html
    May 2014
    MA
    What are you cutting that you need one for?
    Oct 2005
    Quote Originally Posted by EricSchimel View Post
    I am cutting pvc board 1/8 to 3/8.
    Jan 2016
    Phoenix Arizona
    Not that one, but the design looks good.
    I have used this one and can vouch for it's appropriate "pressure".
    https://store.shopbottools.com/collections/accessories/products/cnc-pressure-foot
    cnc routing, portland or
    no need for one for that just use a straight 2f bit. if you use a 1/16" bit on the 1/8" and a 1/18" on the thicker you should have no issues. I can cut really small parts out with just a vacuum holddown. I use a climb cut as that leaves the shavings to stick on the scrap.
    Oct 2005
    Default bit
    Hi Knight
    where did you purchase the 1/16 bits from?
    Dec 2011
    Rapid City, SD
    paul60: I like the ball bearings used in those examples. Just cut over 30 sheets of paper backed veneer with the Donek drag knife. Still on lighhouse motor vac system, and had issues with edge trying to lift, as veneer bled just enough vac to be a problem. Ended up using masking tape around perimeter to keep it down, which took its toll on the time involved. This would have been a lot nicer, especially at that price!
    Thanks for bringing this up - next batch like this and I'll gladly drop the coin to control things with a pressure foot.
    Jeff
    Quote Originally Posted by paul60 View Post
    Hi Knight
    hey are amana there are others I get them from amazon where else (G) but I can get them locally.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    https://www.amazon.com/Whiteside-Rou...n%3A8557106011
    Quote Originally Posted by jTr View Post
    Jeff
    how small are your parts? I can cut some pretty small parts with a 1/16" downcut. I just cut a bunch of parts that are 1.5"x.375 out of 1/8" Baltic at 2ips with a 1/16" down cut I have cut laminate and such with it too it does a great job and parts tend to stay in place. just cut a bunch of luan 1/8" plywood at 3ips with that same bit
    ok I am cutting these small parts with a 1/16" 2f downcut but at 2ips and 16k rpm in a single pass out of 1/8" baltic. I used vacuum but I often cut smaller parts by nailing the sheet down.
    https://www.youtube.com/watch?v=99DB...r#action=share
