learning curve
You learn something just about every time you use it...
I learned just a few months ago that even a bad bicycle helmet makes the corners of the Bot quite a bit softer...
The best way to see what you will be cutting in Vectric is to turn off all the line-work layers and then turn on the toolpath layers one at a time...
