Is there anyone cutting Coroplast with the Bot and if so what tooling and parameters?
Bill
Bill
I've cut a ton of that stuff. I usually use a Donek D4 drag knife with really good results. Router bits leave straggley bits on the end...
http://digitallyfabbed.com/#/rocket-1/
I did all of these booth walls with Coroplast too:
https://goo.gl/photos/ZeF22bzZnQ9QxYxa7
a new o-flute with max rpms regular cut 2 to 3 ips usually cuts it cleanly. I have cut 1/8" to 1/2" with this method. it does not always get all the tabs depending on the sharpness of the bit.
Thanks Guys! I'll give give both methods a try.
Bill
I wrote a quick guide on cutting coroplast :
https://sketchup.dozuki.com/Guide/Ho...last+rocket/20
There's video in there of a drag knife running if you haven't seen one go.
