During the process of releasing the Doors.Exe program (which started as a Linux project), I've had many inquiries about the programming tools that I use to write programs that generate SBP files. For Linux users, the answer is simple: Do a full install of RedHat Fedora Core 3 and you'll have all the tools that you need.
Windows XP is a different situation entirely. On April 1st, when I thought I could spend a few minutes to compile my program to generate an EXE file, I learned that my existing tools (2 Borland compilers and 2 Microsoft compilers) were not going to work. Either they produced an EXE file that wouldn't work on Windows XP or they generated a file that would be too large to email. After a little head scratching, a little hand wringing, and a few hours searching the Internet, I found the combination of programs that works well for me.
If any of you are interested, send me an email and I'll send you a list of the programs that I use that closely approximate the Linux environment that you can download without cost from the Internet. (You will need a fairly high speed connection because the total size of the files is more than 100 megabytes.)
-Mike
miker@xmission.com
