Results 1 to 10 of 11
Thread: gantry wont stop when using key pad
    Jan 2017
    Default gantry wont stop when using key pad
    I have a prs alpha 8 x 4
    I bought it second hand a while ago. I was running it occasionally
    I got sick of the flexible plastic strip that supports the wires. so I fitted energy chain.
    now I have created a problem
    when I use the key pad on the keyboard and press the down button the gantry moves towards me but when I stop pressing it the gantry continues to move and will crash if I don't hit the emergency stop.
    can anyone help me work out what I have done
    thanks alan
    It sounds like you have fixed distance set on your keypad
    Jan 2017
    could do I will look at that in the morning .
    it doesn't do it if I press up though.
    any other ideas
    thanks alan
    I think that you set it for each axis
    To start with, what version of SB3 are you running? A test of how good your USB connection should be done.
    Jun 2001
    Austin, TX
    Just thought, Is the keyboard down button sticking?
    Jan 2017
    not sure . I will check later on. how do I check the usb conection
    Jan 2017
    Quote Originally Posted by waynelocke View Post
    I was thinking that . it doesn't seem to be sticking but I couldn't replicate the problem today
    Jan 2017
    i didn't experience the same problem today so I'm not sure whats going on. everything worked as normal. i didn't try running anything yet but it worked manually
    also i realised i was wrong in the buttons. it is left and right i meant . not up and down
    Jan 2017
    I'm not great on the software yet. what have i set for each axis.
    i don't think i changed any settings
