Results 1 to 4 of 4
Thread: Spindle still spinning long time
    Sep 2015
    South Carolina
    Default Spindle still spinning long time
    I have a 5hp spindle with Yaskawa V1000 and I can not seem to find a way to slow the spindle continuing to spin after a carve or cut to change for another carve or cut. I have changed the deceleration time and it does not seem to work. Can anyone help me with this. It spins for about 2 minutes before it stops. or is this normal...Thanks
    Apr 2007
    Marquette, MI
    Since you are playing in the VFD parameters, you might want to check to make sure that dynamic braking is enabled. Might be parameter name "Stop Method". Ramp to stop is the option I suggest.
    Gary Campbell
    GCnC Control
    GCnC411(at)gmail(dot)com
    Servo Controller Upgrades
    Albert Einstein
    Sep 2015
    South Carolina
    Thanks Gary, that was it. mine was set to coast to stop. Man your knowledge is vast. If you ever write a book I will certainly
    purchase it.
    Apr 2007
    Marquette, MI
    Mark....
    Send a 7 figure advance, I will take a couple years to write it, we split the take.
    Gary Campbell
    GCnC Control
    Albert Einstein
